Include required information
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)" NAME="Raspbian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
uname-r
5.10.17-v8+
syncthing -version
syncthing v1.14.0 "Fermium Flea" (go1.16 linux-arm) deb@build.syncthing.net 2021-02-26 12:21:13 UTC [noupgrade]
- Firefox 86
Nginx as reverse proxy
Because I have more services installed on the PI, I use Nginx as a reverse proxy.
This is the configuration
server {
listen 80;
listen [::]:80;
server_name sync.thing;
autoindex off;
location / {
allow 192.168.178.0/24;
allow fd00::/32;
expires max;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Port $server_port;
proxy_set_header Host localhost;
proxy_set_header X-Real-IP $remote_addr;
proxy_pass http://localhost:8384/;
proxy_read_timeout 600s;
proxy_send_timeout 600s;
deny all;
location ~ \.php$ {
deny all;
location ~ /\.ht {
deny all;
What happened?
- I’m able to access the url
http://sync.thing/
. - It shows the expected page.
- I was able to setup a connection to an other Syncthing node.
- The choose folder was synced.
- Suddenly the display of all information disappeard.
- In the Devtools I see thousands of requests
- When I open http://sync.thing/ in a private Browser tab everything works fine
- But also in the private Browser tab there are thousands of requests to
http://sync.thing/rest/events?since=19
