Syncthing not running in MacOS Sierra Beta
Got some more failures:
[AKFMZ] 00:58:53 INFO: TLS handshake (BEP/tcp): read tcp 10.0.1.11:22000->162.216.226.31:42242: read: connection reset by peer
[AKFMZ] 00:58:53 INFO: TLS handshake (BEP/tcp): EOF
[AKFMZ] 01:00:54 INFO: TLS handshake (BEP/tcp): read tcp 10.0.1.11:22000->162.216.226.31:42253: read: connection reset by peer
[AKFMZ] 01:02:54 INFO: Failed to exchange Hello messages with ...omitted... (xxx.xxx.xxx.xx:42257): write tcp 10.0.1.11:22000->162.216.226.31:42257: write: broken pipe
[AKFMZ] 01:02:54 INFO: TLS handshake (BEP/tcp): EOF
To be clear, I consider this a problem with macOS and not Syncthing. I expect Apple to resolve it if you report it to them, as you should as a beta tester. There is nothing we can do from Synching side at the moment, posting logs here doesn’t help.
Agreed, discovered it happens on more places than just Syncthing. Posted here only for searchability in case people have a similar problem.
Just in case someone else reads this, it’s caused by ntpd.
Running sudo launchctl unload /System/Library/LaunchDaemons/org.ntp.ntpd.plist will fix it temporarily.
source: https://forums.docker.com/t/docker-beta-for-mac-does-not-work-and-hangs-frequently-on-macos-10-12/18109/5
Apparently a behavior change in Sierra triggers a Go runtime bug. That bug will be fixed in a Go release quite soon so we’ll be fine then.
… which should be fixed in Go 1.6.3 released today, meaning that this build of the 0.14.0 release candidate should work fine on Sierra. Do test! :slight_smile:
works! :slight_smile:
I’m getting the same error messages after upgrading to Syncthing 0.14.2 on a DNS-320 NAS (Linux arm-32 2.6.31.8).
[XXXXX] 08:53:09 INFO: Failed to exchange Hello messages with XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX (192.168.1.167:50458): EOF
[XXXXX] 08:53:16 INFO: TLS handshake (BEP/tcp): EOF
[XXXXX] 08:53:24 INFO: TLS handshake (BEP/tcp): EOF
[XXXXX] 08:53:46 INFO: Failed to exchange Hello messages with XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX (192.168.1.109:51064): EOF
[XXXXX] 08:54:00 INFO: Failed to exchange Hello messages with XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX (192.168.1.101:51163): EOF
[XXXXX] 08:54:05 INFO: TLS handshake (BEP/tcp): EOF
[XXXXX] 08:54:11 INFO: TLS handshake (BEP/tcp): EOF
I have no problem an a 64bit Ubuntu 14.04 machine with the same version of Syncthing. Maybe the fix in the Go language hasn’t reached the arm version yet?
Check the other sides logs.
I set STTRACE to upnp,nat,pmp,discovery.
I’m getting a bunch of these messages:
[XXXXX] 2016/07/28 09:53:06.824175 tcp_listen.go:113: INFO: TLS handshake (BEP/tcp): EOF
[XXXXX] 2016/07/28 09:53:08.441473 local.go:176: DEBUG: discover: Received local announcement from 192.168.1.109:61988 for XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
[XXXXX] 2016/07/28 09:53:08.444235 local.go:208: DEBUG: discover: Registering addresses for XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
[XXXXX] 2016/07/28 09:53:08.445084 local.go:242: DEBUG: discover: Reconstructed URL is &url.URL{Scheme:"tcp", Opaque:"", User:(*url.Userinfo)(nil), Host:"192.168.1.109:22000", Path:"", RawPath:"", RawQuery:"", Fragment:""}
[XXXXX] 2016/07/28 09:53:08.445533 local.go:244: DEBUG: discover: Replaced address 0.0.0.0 in tcp://0.0.0.0:22000 to get tcp://192.168.1.109:22000
Do you want me to send more output?
Here is some more:
[XXXXX] 2016/07/28 10:15:47.743355 service.go:179: INFO: Failed to exchange Hello messages with XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX (192.168.1.101:52325): EOF
[XXXXX] 2016/07/28 10:15:52.172839 tcp_listen.go:113: INFO: TLS handshake (BEP/tcp): EOF
I had no problem before upgrading to v14. There was no change in the router’s configuration or anywhere else in the network.
(I’m only limited to write 3 posts to this thread as a new user…)
It just looks like you either have a very bad connection, or some firewall gets in the way.
I have not tested that exactly build, but homebrew golang-1.6.3 / syncthing-0.14.2 work fine for me the first time on Sierra Beta (16A254g). Earlier versions did not (not tested all of them).
macOS Sierra beta 4 was released a few hours ago and broke go/syncthing again.
Awesome :slight_smile:
There is a hint of a fix for the current problem.
Looks like there will be a fix soon in Go 1.7 (rc5)
Go 1.4 was not updated yet, so bootstrapping with homebrew on macOS Sierra beta 4 / public beta 3 fails. Currently I don’t know a simple/automated way to build / run Syncthing on macOS Sierra, but the Go team promised to update 1.4 when Apple released the final Sierra version.
You don’t need to bootstrap Go. Just downloading 1.7rc5 and building Syncthing should work fine.
I meant automated building HEAD with homebrew (brew install syncthing --HEAD) fails because it wants to bootstrap go.
[edit] I see you can skip dependencies with --ignore-dependencies, so manually installing Go (don’t forget to setup $GOPATH) and it should work with homebrew again.
[edit2] Looks like it is not that easy, homebrew likes to keep things separate for good reasons and ignores the user specific environment (./build.sh: line 14: go: command not found). Back to checkout/compile by hand. It’s a beta after all, not complaining.
