Syncthing not patient enough for my wife
She who must be obeyed runs Windows 10 on her laptop with SyncTrayzor.
She rarely reboots and keeps multiple documents and multiple tabs in multiple browsers open for days.
I suspect that there is lots of crapware and other stuff to sort out.
The end result is that it runs s l o w l y.
Looking at the gui on the local pi, I noticed that she hadn’t connected recently.
I found that Synctrayzor wasn’t running, started it, updated it and got syncthing going again.
Still didn’t connect.
Currently
 Address	dynamic
relay://136.243.66.99:22067
quic://192.168.1.132:22000
context deadline exceeded (15:52:16)
tcp://192.168.1.132:22000
i/o timeout (15:52:06)
tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000
quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000
 Last seen	2019-11-12 16:37:00
Log
2019-12-09 04:01:40 My ID: 3YBZSGE-...
2019-12-09 04:01:41 Single thread SHA256 performance is 45 MB/s using minio/sha256-simd (44 MB/s using crypto/sha256).
2019-12-09 04:01:41 Hashing performance is 41.10 MB/s
2019-12-09 04:01:42 Ready to synchronize Pdocs (sendreceive)
2019-12-09 04:01:42 Ready to synchronize Pdocuments (sendreceive)
2019-12-09 04:01:42 Ready to synchronize Phhg (sendreceive)
2019-12-09 04:01:42 Ready to synchronize Ppics (sendreceive)
2019-12-09 04:01:42 Ready to synchronize "stStuff" (xkqsj-csnz5) (sendreceive)
2019-12-09 04:01:42 Ready to synchronize "Dvideos" (7sth4-fdehd) (sendreceive)
2019-12-09 04:01:42 Ready to synchronize Ddocuments (sendreceive)
2019-12-09 04:01:42 ...
2019-12-09 04:01:42 Ready to synchronize Dpictures (sendreceive)
2019-12-09 04:01:42 Ready to synchronize Ppictures (sendreceive)
2019-12-09 04:01:42 Ready to synchronize Dldocs (sendreceive)
2019-12-09 04:01:42 Ready to synchronize Dmusic (sendreceive)
2019-12-09 04:01:42 Overall send rate is unlimited, receive rate is unlimited
2019-12-09 04:01:42 QUIC listener ([::]:22000) starting
2019-12-09 04:01:42 TCP listener ([::]:22000) starting
2019-12-09 04:01:42 GUI and API listening on 127.0.0.1:8384
2019-12-09 04:01:42 Access the GUI via the following URL: http://127.0.0.1:8384/
2019-12-09 04:01:42 My name is "pi4b"
2019-12-09 04:01:42 Device B3IQ5IL-... is "pie" at [tcp://away.example.co.uk]
2019-12-09 04:01:42 Device CLKW22T-... is "PAULINE-PC" at [dynamic]
2019-12-09 04:01:42 Device NC5XMBX-... is "anzu" at [dynamic]
2019-12-09 04:01:42 Device T23BC6D-... is "monocerus" at [dynamic]
2019-12-09 04:01:42 Device VZN3PZC-... is "unicorn" at [dynamic]
2019-12-09 04:01:43 Completed initial scan of sendreceive folder Dldocs
2019-12-09 04:01:43 Completed initial scan of sendreceive folder "Dvideos" (7sth4-fdehd)
2019-12-09 04:01:43 Completed initial scan of sendreceive folder Ppictures
2019-12-09 04:01:43 Completed initial scan of sendreceive folder "stStuff" (xkqsj-csnz5)
2019-12-09 04:01:44 Completed initial scan of sendreceive folder Phhg
2019-12-09 04:01:44 Completed initial scan of sendreceive folder Pdocuments
2019-12-09 04:01:46 Completed initial scan of sendreceive folder Ppics
2019-12-09 04:01:47 Completed initial scan of sendreceive folder Dpictures
2019-12-09 04:01:55 Completed initial scan of sendreceive folder Ddocuments
2019-12-09 04:01:56 Completed initial scan of sendreceive folder Pdocs
2019-12-09 04:01:59 Completed initial scan of sendreceive folder Dmusic
2019-12-09 04:02:01 quic://0.0.0.0:22000 detected NAT type: Port restricted NAT
2019-12-09 04:02:01 quic://0.0.0.0:22000 resolved external address quic://1.2.3.4:22000 (via stun.syncthing.net:3478)
2019-12-09 04:02:02 Detected 1 NAT service
2019-12-09 04:11:41 Established secure connection to B3IQ5IL-... at 192.168.1.12:22000-5.6.7.8:52868/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2019-12-09 04:11:41 Device B3IQ5IL-... client is "syncthing v1.3.2" named "pie" at 192.168.1.12:22000-5.6.7.8:52868/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2019-12-09 04:31:44 Sent usage report (version 3)
2019-12-09 11:43:01 Established secure connection to NC5XMBX-... at [fe80::fdec:66ea:7309:9b92%eth0]:22000-[fe80::dd5b:263e:c0bf:2eff%eth0]:45860/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2019-12-09 11:43:01 Device NC5XMBX-... client is "syncthing v1.3.2" named "anzu" at [fe80::fdec:66ea:7309:9b92%eth0]:22000-[fe80::dd5b:263e:c0bf:2eff%eth0]:45860/tcp-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2019-12-09 13:10:47 Enabled debug data for "connections"
2019-12-09 13:10:55 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:10:55 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:10:55 failed to connect to CLKW22T-... 99
2019-12-09 13:10:55 Reconnect loop for T23BC6D-... []
2019-12-09 13:10:55 Reconnect loop for VZN3PZC-... []
2019-12-09 13:10:55 sleep until next dial 1m0s
2019-12-09 13:11:55 Reconnect loop
2019-12-09 13:11:55 Reconnect loop for CLKW22T-... [quic://192.168.1.132:22000 quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= tcp://192.168.1.132:22000 tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000]
2019-12-09 13:11:55 Dialer for relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= is disabled
2019-12-09 13:11:55 dialing CLKW22T-... tcp://192.168.1.132:22000 prio 9
2019-12-09 13:11:55 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 9
2019-12-09 13:12:05 dialing CLKW22T-... tcp://192.168.1.132:22000 error: dial tcp 192.168.1.132:22000: i/o timeout
2019-12-09 13:12:05 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial tcp [fe80::7191:68c7:ffd4:f383%eth0]:22000: i/o timeout
2019-12-09 13:12:05 failed to connect to CLKW22T-... 9
2019-12-09 13:12:05 dialing CLKW22T-... quic://192.168.1.132:22000 prio 99
2019-12-09 13:12:05 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 99
2019-12-09 13:12:15 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:12:15 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:12:15 failed to connect to CLKW22T-... 99
2019-12-09 13:12:15 Reconnect loop for T23BC6D-... []
2019-12-09 13:12:15 Reconnect loop for VZN3PZC-... []
2019-12-09 13:12:15 sleep until next dial 1m0s
2019-12-09 13:13:15 Reconnect loop
2019-12-09 13:13:15 Reconnect loop for CLKW22T-... [quic://192.168.1.132:22000 quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= tcp://192.168.1.132:22000 tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000]
2019-12-09 13:13:15 Dialer for relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= is disabled
2019-12-09 13:13:15 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 9
2019-12-09 13:13:15 dialing CLKW22T-... tcp://192.168.1.132:22000 prio 9
2019-12-09 13:13:25 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial tcp [fe80::7191:68c7:ffd4:f383%eth0]:22000: i/o timeout
2019-12-09 13:13:25 dialing CLKW22T-... tcp://192.168.1.132:22000 error: dial tcp 192.168.1.132:22000: i/o timeout
2019-12-09 13:13:25 failed to connect to CLKW22T-... 9
2019-12-09 13:13:25 dialing CLKW22T-... quic://192.168.1.132:22000 prio 99
2019-12-09 13:13:25 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 99
2019-12-09 13:13:35 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:13:35 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:13:35 failed to connect to CLKW22T-... 99
2019-12-09 13:13:35 Reconnect loop for T23BC6D-... []
2019-12-09 13:13:35 Reconnect loop for VZN3PZC-... []
2019-12-09 13:13:35 sleep until next dial 1m0s
2019-12-09 13:14:35 Reconnect loop
2019-12-09 13:14:35 Reconnect loop for CLKW22T-... [quic://192.168.1.132:22000 quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= tcp://192.168.1.132:22000 tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000]
2019-12-09 13:14:35 Dialer for relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= is disabled
2019-12-09 13:14:35 dialing CLKW22T-... tcp://192.168.1.132:22000 prio 9
2019-12-09 13:14:35 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 9
2019-12-09 13:14:45 dialing CLKW22T-... tcp://192.168.1.132:22000 error: dial tcp 192.168.1.132:22000: i/o timeout
2019-12-09 13:14:45 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial tcp [fe80::7191:68c7:ffd4:f383%eth0]:22000: i/o timeout
2019-12-09 13:14:45 failed to connect to CLKW22T-... 9
2019-12-09 13:14:45 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 99
2019-12-09 13:14:45 dialing CLKW22T-... quic://192.168.1.132:22000 prio 99
2019-12-09 13:14:55 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:14:55 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:14:55 failed to connect to CLKW22T-... 99
2019-12-09 13:14:55 Reconnect loop for T23BC6D-... []
2019-12-09 13:14:55 Reconnect loop for VZN3PZC-... []
2019-12-09 13:14:55 sleep until next dial 1m0s
2019-12-09 13:15:55 Reconnect loop
2019-12-09 13:15:55 Reconnect loop for CLKW22T-... [quic://192.168.1.132:22000 quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= tcp://192.168.1.132:22000 tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000]
2019-12-09 13:15:55 Dialer for relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= is disabled
2019-12-09 13:15:55 dialing CLKW22T-... tcp://192.168.1.132:22000 prio 9
2019-12-09 13:15:55 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 9
2019-12-09 13:16:05 dialing CLKW22T-... tcp://192.168.1.132:22000 error: dial tcp 192.168.1.132:22000: i/o timeout
2019-12-09 13:16:05 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial tcp [fe80::7191:68c7:ffd4:f383%eth0]:22000: i/o timeout
2019-12-09 13:16:05 failed to connect to CLKW22T-... 9
2019-12-09 13:16:05 dialing CLKW22T-... quic://192.168.1.132:22000 prio 99
2019-12-09 13:16:05 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 99
2019-12-09 13:16:05 Enabled debug data for "dialer"
2019-12-09 13:16:15 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:16:15 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:16:15 failed to connect to CLKW22T-... 99
2019-12-09 13:16:15 Reconnect loop for T23BC6D-... []
2019-12-09 13:16:15 Reconnect loop for VZN3PZC-... []
2019-12-09 13:16:15 sleep until next dial 1m0s
2019-12-09 13:17:15 Reconnect loop
2019-12-09 13:17:15 Reconnect loop for CLKW22T-... [quic://192.168.1.132:22000 quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= tcp://192.168.1.132:22000 tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000]
2019-12-09 13:17:15 Dialer for relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= is disabled
2019-12-09 13:17:15 dialing CLKW22T-... tcp://192.168.1.132:22000 prio 9
2019-12-09 13:17:15 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 9
2019-12-09 13:17:25 dialing CLKW22T-... tcp://192.168.1.132:22000 error: dial tcp 192.168.1.132:22000: i/o timeout
2019-12-09 13:17:25 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial tcp [fe80::7191:68c7:ffd4:f383%eth0]:22000: i/o timeout
2019-12-09 13:17:25 failed to connect to CLKW22T-... 9
2019-12-09 13:17:25 dialing CLKW22T-... quic://192.168.1.132:22000 prio 99
2019-12-09 13:17:25 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 99
2019-12-09 13:17:35 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:17:35 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:17:35 failed to connect to CLKW22T-... 99
2019-12-09 13:17:35 Reconnect loop for T23BC6D-... []
2019-12-09 13:17:35 Reconnect loop for VZN3PZC-... []
2019-12-09 13:17:35 sleep until next dial 1m0s
2019-12-09 13:18:35 Reconnect loop
2019-12-09 13:18:35 Reconnect loop for CLKW22T-... [quic://192.168.1.132:22000 quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= tcp://192.168.1.132:22000 tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000]
2019-12-09 13:18:35 Dialer for relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= is disabled
2019-12-09 13:18:35 dialing CLKW22T-... tcp://192.168.1.132:22000 prio 9
2019-12-09 13:18:35 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 9
2019-12-09 13:18:45 dialing CLKW22T-... tcp://192.168.1.132:22000 error: dial tcp 192.168.1.132:22000: i/o timeout
2019-12-09 13:18:45 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial tcp [fe80::7191:68c7:ffd4:f383%eth0]:22000: i/o timeout
2019-12-09 13:18:45 failed to connect to CLKW22T-... 9
2019-12-09 13:18:45 dialing CLKW22T-... quic://192.168.1.132:22000 prio 99
2019-12-09 13:18:45 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 99
2019-12-09 13:18:55 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:18:55 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:18:55 failed to connect to CLKW22T-... 99
2019-12-09 13:18:55 Reconnect loop for T23BC6D-... []
2019-12-09 13:18:55 Reconnect loop for VZN3PZC-... []
2019-12-09 13:18:55 sleep until next dial 1m0s
2019-12-09 13:19:55 Reconnect loop
2019-12-09 13:19:55 Reconnect loop for CLKW22T-... [quic://192.168.1.132:22000 quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= tcp://192.168.1.132:22000 tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000]
2019-12-09 13:19:55 Dialer for relay://136.243.66.99:22067/?id=OEDHLSY-...&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy= is disabled
2019-12-09 13:19:55 dialing CLKW22T-... tcp://192.168.1.132:22000 prio 9
2019-12-09 13:19:55 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 9
2019-12-09 13:20:05 dialing CLKW22T-... tcp://192.168.1.132:22000 error: dial tcp 192.168.1.132:22000: i/o timeout
2019-12-09 13:20:05 dialing CLKW22T-... tcp://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial tcp [fe80::7191:68c7:ffd4:f383%eth0]:22000: i/o timeout
2019-12-09 13:20:05 failed to connect to CLKW22T-... 9
2019-12-09 13:20:05 dialing CLKW22T-... quic://192.168.1.132:22000 prio 99
2019-12-09 13:20:05 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 prio 99
2019-12-09 13:20:15 dialing CLKW22T-... quic://192.168.1.132:22000 error: dial: context deadline exceeded
2019-12-09 13:20:15 dialing CLKW22T-... quic://[fe80::7191:68c7:ffd4:f383%25eth0]:22000 error: dial: context deadline exceeded
2019-12-09 13:20:15 failed to connect to CLKW22T-... 99
2019-12-09 13:20:15 Reconnect loop for T23BC6D-... []
2019-12-09 13:20:15 Reconnect loop for VZN3PZC-... []
2019-12-09 13:20:15 sleep until next dial 1m0s
etc., etc.
Is there a way to configure a shorter timeout?
It looks like timeouts were reduced around the time quic was introduced. Am I right?
They simply can’t connect to each other using tcp (thus dialing is eventually timing out). This has nothing to do with quic (introducing which didn’t change anything about tcp timeouts). In any case it’s not really imaginable that the computer can’t establish a tcp connection in time due to the load of a few tabs and documents (I don’t think any load should be able to do that). The usual suspect is a firewall.
I’ll look at firewall on win 10. It’s not the linux one.
I got access to wife’s laptop just after boot. Turned on debug for connections and dialler on win10 st and noticed no dial messages.
Fixed by plugging in ip address of pi into win10 st.
So it’s runing now.
