Syncthing is stuck with all folders showing 'offline'
Syncthing is stuck with all folders showing as ‘offline’. The Android app on the same network is also frozen (all folders greyed out).
If I use the web GUI, folders show as ‘up to date’.
I’ve tried restarting the daemon (both from the desktop gui and from the web gui). I’ve tried restarting my computer. The Daemon output shows no errors and the last line is
INFO: Joined relay relay://{my ip}
Does anyone know what’s happening?
Just to add - I tried pausing the device (the PC that this gui is on), then resuming. Now it’s stuck showing the device as ‘Disconnected’
Folders can’t show offline, so I guess I am not sure what you mean.
Suggest you post screenshots and logs from both sides.
