I have installed the latest version of Syncthing on my Debian 7 VPS Server and can’t access the server from another computer as I don’t have a web gui on my Debian server. I am trying to access the server with the IP address of my Debian Server and port 8384, but cannot access the Web Gui. I have confirmed that Syncthing is running by doing a netstat -an and can see that it is listening on port 8384.
On my Windows 10 Machine I enter 81.4.x.x:8384, but I can’t reach the Syncthing Gui. I have turned off my Windows 10 Firewall to remove that from the equation. In addition, I have added:
-A INPUT -p udp -m udp --dport 8384 -j ACCEPT -A INPUT -p tcp -m tcp --dport 8384 -j ACCEPT
to my Iptables file.
My other issue is that I can’t seem to get Syncthing started when the server boots. I’m using a script that I downloaded from the web.
I have copied the syncthing executable to /usr/local/bin/ and have given it root privileges and it is executable. When I issue the command in etc/init.d/
./syncthing
the program does not launch.
If I issue
./syncthing start
it will launch. How do I get this script to autolaunch with root privileges?
