Syncthing having trouble with Docker bind mounts on mergerfs
I recently migrated from a single btrfs drive (where I used docker and this configuration to happily run Syncthing):
services:
  syncthing:
    image: syncthing/syncthing
    container_name: syncthing
    environment:
      - PUID=1501
      - PGID=1501
    volumes:
      - ./data/config:/config
      - /mnt/chungus/private/syncthing:/chungus
    ports:
      - 8384:8384
      - 22000:22000
      - 21027:21027/udp
to a mergerfs mount with two btrfs drives in a pool. I copied everything across from the btrfs drive to the mergerfs mount. Permissions remained the same, all my other Docker containers are reading/writing without issue.
Syncthing can’t seem to see the folders I’ve mounted.
If I docker exec -it syncthing /bin/bash into the container, I can see the folders and their contents.
I have ran
chown -R backup:backup /mnt/chungus/private/syncthing
chmod -R 775 /mnt/chungus/private/syncthing
Unsurprisingly, this has no effect since the permissions are definitely correct. (backup is the user with id 1501)
This is what I’m getting in the syncthing logs:
WARNING: Failed to create folder root directory mkdir /mnt/chungus: file exists
WARNING: Error on folder "Tetst" (2gnnk-xvcfr): folder path missing
I change the mount in Docker to where the old btrfs drive is mounted, and things start working again.
Anyone had a similar experience?
Worth noting that running syncthing on the host does not exhibit the same behaviour.
Thanks!
Fixed - a parent directory did not have execute set on it :facepalm:
