This morning I noticed that the SyncThing icon in the menu of my Macbook Pro was in the status indicating that it was updating. Usually this is a quick affair but I noticed that it was going on far longer than usual.
I have a bookmark in my Firefox browser that immediately opens SyncThing’s browser page. This would not open, " Unable to connect. Firefox can’t establish a connection to the server at localhost:8384."
This would be my one and only critique of the SyncThing interface, when there is a problem like this, you have no info or controls to trouble shoot.
Returning to the Syncthing menu icon: it’s going back and forth between “Unavailable > SyncThing Service (Stopped)” and “Running (offline) > SyncThing Service (Running)”
From this menu, neither Start or Restart has any effect.
I’ve opened the Config Folder and looked at the logs, a panic-20240713-123426.reported file is constantly being produced but I do not know what to look for in them.
I run SyncThing between two Apple Macs: Macbook Pro / MacOS Catalina and a Mac Pro (2019) rackmount / MacOS Ventura. Also, via MobiusSync, I have some of the Syncthing folders on an iPad Pro.
My first suspicion was my recent upgrade to Ventura on the Mac Pro but SyncThing worked as expected for several days until this morning.
The machines are definitely not syncing, I’ve done a few tests and nether one of the machines are currently syncing. The Mac Pro SyncThing browser page indicates that the Macbook Pro is “Disconnected.”
But then it also will show a Connection, start syncing (showing %), but then go back to a Disconnected status. It indicates that it is out of sync, 4 files, my test files.
I have become incredibly dependent on SyncThing, it is the foundation of my work process. I can easily work on large projects, on both machines, and not work about anything being out of sync. Except when I do something foolish like when I open the same file on both machines and work on it. But SyncThing handles this mistake with aplomb as well.
In fact, SyncThing works so well that I run it of years without any real attention – this is also the problem, my SyncThing tech skills go dormant and become forgotten.
I am not sure how to proceed, what to fix? I am dependent on the kindness of strangers.
Thanks.
PS As I’ve been writting this I’ve been watching the status page on the Mac Pro, reporting the status of the Macbook Pro, the page is being updated so they are talking to each other.
