Hello everubody,
I recently acquired the new RPi 2 and decided to go with syncthing for my backup hard disk (USB HD connected to Raspberry Pi)
My problem is that even if the syncthing GUI is available from the local machine (localhost:9090 in my case), my PC which is on the same LAN is not able to connect to the GUI.
On the 8080 port runs the web interface of Kodi which is accessible just fine.
I wonder if I did anything wrong or if I should set something up (in the config files).
Any ideas ? Thanks
