syncthing-gtk not starting
Yesterday the ppa containing Syncthing-gtk for Ubuntu updated to version 0.9.3. Since then it doesn’t launch at all. In the terminal I get the following error:
Gtk-Message: Failed to load module "unity-gtk-module"
I StatusIcon    Using backend StatusIconGTK3 (primary)
I App
I App           Syncthing-GTK started and running in notification area
/usr/lib/python2.7/dist-packages/syncthing_gtk/statusicon.py:453: PyGIWarning: AppIndicator3 was imported without specifying a version first. Use gi.require_version('AppIndicator3', '0.1') before import to ensure that the right version gets loaded.
  from gi.repository import AppIndicator3 as appindicator
W StatusIcon    StatusIcon: Using backend StatusIconAppIndicator (fallback)
Traceback (most recent call last):
  File "/usr/lib/python2.7/dist-packages/syncthing_gtk/daemon.py", line 398, in _request_config
	RESTRequest(self, "system/config", self._syncthing_cb_config, self._syncthing_cb_config_error).start()
  File "/usr/lib/python2.7/dist-packages/syncthing_gtk/daemon.py", line 1045, in init
	self.connect("event", self._socket_event)
TypeError: argument connectable: Expected Gio.SocketConnectable, but got unicode
In the system tray icon it just says “Connecting to daemon” and never connects.
Clicking “Show Window” just shows a plain window as shown below
I have this installed on two machines running Ubuntu 17.10 and neither work.
Windows here and 0.9.3 did the same. When I checked with ProcessExplorer I could see that syncthing was constantly started by Syncthing-GTK, then it exits and is started again. I tried a clean install of Syncthing-GTK 0.9.3 but that did not help. Then a clean install of 0.9.2.7 worked as expected.
