@kozec Syncthing GTK fails when downloading the syncthing binary on a first start on a fresh Linux Mint KDE Mate System … It is simply not downloaded and the progress bar is not moving farther.
I solved it another way. I downloaded and installed the syncthing binary myself, after that Syncthing GTK recognized it. After that I was able to continue the setup process
I observed the Syncthing GTK When installing on Linux Mint cinamon or Linux Mint KDE Mate, behaves differently.
On both operating systems I installed Syncthing GTK from a deb package. In Linux Mint Cinamon everything worked smoothly. Syncthing was downloaded in the “/home/rick/.local/bin/” On the MATE KDE setup of Syncthing GTK has not worked, the download of the syncthing binary did not start. I had to install it manually. These happened in the read-only “/ usr / bin” folder. This prevented the automatic update of Syncthing. At least I was able to continue the setup process of Sncthing GTK. Then I copied the Syncthing binary from the “/ usr / bin” folder in a writable folder and in Syncthing GTK I changed the path.
Perhaps it is because, on Linux Mint Cinamon a 64-bit version runs.
Read-only /usr/bin shouldn’t be problem, ST-GTK is not going to write there anyway. But on KDE-based distro, there is chance of having some library missing.
Having log or knowing what exactly “MATE KDE setup” is would help…
