Hello, I wanted to find out if the program Syncthing can be used for synchronization of files in Alfresco, ie desktop and Alfresco database
thank you for the info
Vladimir
Vladimir
I don’t know Alfresco. Syncthing syncs files. So if it uses files as storage, it technically works. Syncing “live” databases is most often a bad idea though. With “live” I mean a database that is currently in use and written to, as opposed to a db copy/backup. If the database is continuously written to, Syncthing can’t sync those changes as by the time it wants to send data, it has already changed. If it’s lots of files, Syncthing will sync them individually, with a very high risk of creating an inconsistent state (from the view of the db).
