When I change the Folder path it always goes into the files directory. Example root/Data/AppData/syncthing/config/Storage2 which is a ssd drive.
i would like the Folder path to go to Storage2 which is a hard disk with greater capacity but I am struggling to know the path commands to it.
As you can see it is located in Location area and not the Files area
The Following may explain betterProcessing: PXL_20240808_115010095.MP~2.jpg… Processing: PXL_20240808_115147653.MP~2.jpg…
Thank you in advance New User
