Hello,
I am experiencing very slow syncing with syncthing (0.14.50).
I created 2 test cases to demonstrate…
Folder - 58 177 files 11 684 folder ~977 MiB Host A, Host B - both Core i3 machines with enough RAM
- scenario “empty copy”
Host A: contains the folder Host B: empty folder
- sync run with unison: 17 seconds to scan, 1:48 to copy
- sync run with synthing: 30 seconds to scan, ??? to complete
After 15 minutes:
| Global status | 58 177 11 684 ~977 MiB |
| Local status | 0 1 029 ~129 KiB |
| Unsynchronized | 68868 položky, ~977 MiB |
- Scenario “identical copies”
Host A: contains the folder Host B: contains the same (unison-ed) folder
- sync run with unison: scan: 17 seconds, full run: 24 seconds
- sync run with syncthing: scan: 39 seconds, full run: 43% “immediately done”, then started to crawl… after 7 minutes:
| Globální status | 58 177 11 684 ~977 MiB |
| Místní status | 58 177 11 684 ~977 MiB |
| Nesesynchronizované položky | 26604 položky, ~414 MiB |
WTF is going on? Why unison takes a minute and syncthing can’t finish the first sync in 15 minutes?
