can i run 2 different versions of syncthing on the same pc ? any suggestion?, thanks in advance
Not sure if you meant two different instances of the same syncthing binary (= same version) or two different syncthing versions, e.g. 0.13 and 0.14, but both is possible. You just have to make sure to use different directories for -home
and of course you have to change the listen ports. Local discovery, however, will only work for one of these instances.
