Running ST 0.49 on several machines, but it keeps crashing on a raspberry pi. It started crashing on a 2+ a few weeks ago and after upgrading the pi, continues to crash on a 3+.
When newly installed, ST runs and syncs for several (10s of?) minutes, can sync sever GB of files over a LAN, but then dies. Restarting from the command line yields:
pi@pi:~ $ syncthing
[monitor] 06:20:03 INFO: Starting syncthing
[3Y7FH] 06:20:05 INFO: syncthing v0.14.49 "Dysprosium Dragonfly" (go1.10.3 linux-arm) deb@build.syncthing.net 2018-07-10 15:40:06 UTC [noupgrade]
[3Y7FH] 06:20:05 INFO: My ID: 3Y7FHLY-43ZTNSQ-5DPWLPG-L6VTFVB-2QLCSQJ-D6CIEJZ-NKIWYSP-CJEPVAP
[3Y7FH] 06:20:06 INFO: Single thread SHA256 performance is 19 MB/s using minio/sha256-simd (19 MB/s using crypto/sha256).
[3Y7FH] 06:20:07 INFO: Hashing performance is 17.72 MB/s
[3Y7FH] 06:20:07 FATAL: Error opening database: write /home/pi/.config/syncthing/index-v0.14.0.db/606781.ldb: no space left on device (is another instance of Syncthing running?)
[monitor] 06:20:07 INFO: Syncthing exited: exit status 1
[monitor] 06:20:08 INFO: Starting syncthing
[3Y7FH] 06:20:10 INFO: syncthing v0.14.49 "Dysprosium Dragonfly" (go1.10.3 linux-arm) deb@build.syncthing.net 2018-07-10 15:40:06 UTC [noupgrade]
[3Y7FH] 06:20:10 INFO: My ID: 3Y7FHLY-43ZTNSQ-5DPWLPG-L6VTFVB-2QLCSQJ-D6CIEJZ-NKIWYSP-CJEPVAP
[3Y7FH] 06:20:11 INFO: Single thread SHA256 performance is 19 MB/s using crypto/sha256 (19 MB/s using minio/sha256-simd).
[3Y7FH] 06:20:11 INFO: Hashing performance is 17.50 MB/s
[3Y7FH] 06:20:12 FATAL: Error opening database: write /home/pi/.config/syncthing/index-v0.14.0.db/606781.ldb: no space left on device (is another instance of Syncthing running?)
[monitor] 06:20:12 INFO: Syncthing exited: exit status 1
[monitor] 06:20:13 INFO: Starting syncthing
[3Y7FH] 06:20:14 INFO: syncthing v0.14.49 "Dysprosium Dragonfly" (go1.10.3 linux-arm) deb@build.syncthing.net 2018-07-10 15:40:06 UTC [noupgrade]
[3Y7FH] 06:20:14 INFO: My ID: 3Y7FHLY-43ZTNSQ-5DPWLPG-L6VTFVB-2QLCSQJ-D6CIEJZ-NKIWYSP-CJEPVAP
[3Y7FH] 06:20:15 INFO: Single thread SHA256 performance is 19 MB/s using crypto/sha256 (19 MB/s using minio/sha256-simd).
[3Y7FH] 06:20:16 INFO: Hashing performance is 17.70 MB/s
[3Y7FH] 06:20:16 FATAL: Error opening database: write /home/pi/.config/syncthing/index-v0.14.0.db/606781.ldb: no space left on device (is another instance of Syncthing running?)
[monitor] 06:20:16 INFO: Syncthing exited: exit status 1
[monitor] 06:20:17 INFO: Starting syncthing
[3Y7FH] 06:20:19 INFO: syncthing v0.14.49 "Dysprosium Dragonfly" (go1.10.3 linux-arm) deb@build.syncthing.net 2018-07-10 15:40:06 UTC [noupgrade]
[3Y7FH] 06:20:19 INFO: My ID: 3Y7FHLY-43ZTNSQ-5DPWLPG-L6VTFVB-2QLCSQJ-D6CIEJZ-NKIWYSP-CJEPVAP
[3Y7FH] 06:20:20 INFO: Single thread SHA256 performance is 19 MB/s using crypto/sha256 (19 MB/s using minio/sha256-simd).
[3Y7FH] 06:20:21 INFO: Hashing performance is 17.68 MB/s
[3Y7FH] 06:20:21 FATAL: Error opening database: write /home/pi/.config/syncthing/index-v0.14.0.db/606781.ldb: no space left on device (is another instance of Syncthing running?)
[monitor] 06:20:21 INFO: Syncthing exited: exit status 1
[monitor] 06:20:22 WARNING: 4 restarts in 18.629236285s; not retrying further
pi@pi:~ $
What gives?
