Another update:
And another (bugfix) release. By upgrading the Swift version the new AppTreansportSecurity Layer disabled all internal calls to the syncthing API on El Captain and thus syncthing-bar didn’t work. Be sure to use this release when you are using El Captain! If you are using yosemite there is no immediate reason to upgrade.
Thanks to crahan and alyberty on github
tada…a new release…
finally showing labels instead of ids
kudos to @saesh
- Adding pause on battery support by @saesh
- Update pre bundled to syncthing 0.14.6
