Impossible to connect.
Messages of the monitor:
[monitor] 11:45:40 INFO: Log output saved to file “C:\Users\ut270c00\AppData\Local\Syncthing\syncthing.log”
[monitor] 11:45:40 INFO: Starting syncthing
[Y52TJ] 11:45:42 INFO: syncthing v0.11.20 (go1.4.2 windows-386 default) unknown-
user@syncthing-builder 2015-08-16 13:29:48 UTC [Y52TJ] 11:45:42 INFO: My ID: XXXXXX-…
[Y52TJ] 11:45:42 INFO: Database block cache capacity 25936 KiB
[Y52TJ] 11:45:42 INFO: Starting web GUI on http://127.0.0.1:8384/
[Y52TJ] 11:45:43 INFO: Starting local discovery announcements
[Y52TJ] 11:45:43 INFO: Local discovery over IPv6 unavailable
[Y52TJ] 11:45:43 INFO: Starting global discovery announcements
[Y52TJ] 11:45:43 INFO: Device XXXXXX-… is “st270c01” at [dynamic]
[Y52TJ] 11:45:43 INFO: API listening on 127.0.0.1:8384
[Y52TJ] 11:46:04 INFO: Automatic upgrade: couldn’t fetch release information
Message on the interface web:
Global Discovery = 0/3 (I have the normal adresses + my own discover server with a dynamic DNS)
With CurrPorts:
syncthing.exe TCP 8384 127.0.0.1 0.0.0.0 Listening
syncthing.exe TCP 8384 127.0.0.1 55278 127.0.0.1 ST270C01.pdv270C.mydomain.local Established
syncthing.exe TCP 8384 127.0.0.1 55281 127.0.0.1 ST270C01.pdv270C.mydomain.local Established
syncthing.exe TCP 8384 127.0.0.1 55282 127.0.0.1 ST270C01.pdv270C.mydomain.local Established
syncthing.exe TCP 8384 127.0.0.1 55277 127.0.0.1 ST270C01.pdv270C.mydomain.local Established
syncthing.exe TCP 22000 0.0.0.0 0.0.0.0 Listening
syncthing.exe UDP 21025 0.0.0.0
syncthing.exe UDP 51844 0.0.0.0
syncthing.exe UDP 51845 0.0.0.0
syncthing.exe UDP 51847 0.0.0.0
syncthing.exe TCP 22000 :: :: Listening
syncthing.exe UDP 51846 ::
—> It seems that it is not possible to access UDP ports outside the network
In this network , I do not find a solution to operate syncthing
