Syncthing Android crashes syncing to untrusted machine
Syncthing version: 1.17.0 for both devices
Android version: 11
Linux version: Latest RaspberryPiOS
Syncthing on android crashes when I configure an untrusted folder. I used the webUI because the native UI doesn’t support this feature yet. The RPI says it’s receiving unencrypted data on an encrypted folder and doesn’t write it. remote expects to exchange encrypted data, but is configured for plain data
It looks like Syncthing for Android just doesn’t support untrusted folders yet. Is that correct? A simple fix might be a setting to only use the webUI that way if the android UI doesn’t support something a user could still use it through the webUI.
Thanks @AudriusButkevicius, I should have looked on github.
