Syncthing and Graphene OS - multiple user issue could use help with
Hi all, I have Owner and User 1 profiles setup. I have syncthing on both profiles. I have syncthing configured to boot on startup, runs in background, sync only on wifi and it works great.
The problem is, if syncthing is running on owner and I switch to User 1, syncthing will not start. If I go back to owner and force stop syncthing, then switch back to User 1, syncthing will start and run. The same problem exists vice-versa, unless I end User 1 session, but I don’t like to do that. How can I overcome this so issue?
Thanks all,
You need to tweak a few settings for this to work. Please check https://forum.syncthing.net/t/multiple-users-profiles-on-android/18952/3 for details.
@tomasz86 Thank you!!, exactly what I needed.
