I just set up a VPS with a provider. The instance of ubuntu os stock. I installed syncthing 1.17.0 on it and set up a single directory to test speeds from it to my home network.
It is set up with the default systemd scripts. I have enabled the service to autostart for my username (non root) on the server.
It initially works perfectly. Syarts syncing my files as expected but starts slowing down. Turns out systemd keeps launch8ng new copies of the syncthing process until physical and virtual memory is exhausted. Going on with an high system load until the server becomes completely unresponsive and the provider’s VM triggers a restart of my server.
It takes about 10 minutes for this cycle to occur give or take.
Would repeat, I have not modified any systemd startup files, except to enable the syncthing@username for my account and then start it up. Configuration is very simple. A user login for the web GUI, one sync folder. Send only, no versioning, sync oldest first.
Reviewed the last two hours of output from journalctl. Just the same syncthing output, entries of evidence from random bots trying to ssh their way in…. No errors.
I have not set up any filtering but I don’t know if the image I installed from has anything set up.
