Benjou
(Benjou)
July 24, 2016, 5:13pm
1
Hi all,
Is the latest android app scheduled to be updated on f-droid repo?
All my instances of syncthing have been updated except for my tablet, which I installed in F-droid.
The app is not yet updated (it is in the google play store though…)
Thanks!
xduugu
July 24, 2016, 5:24pm
2
canton7
(Antony Male)
July 24, 2016, 5:25pm
3
Hmm? Yes it is - the maintainers are active on this forum.
xduugu
July 24, 2016, 5:26pm
4
He is? Then he doesn’t use the same username here as on github.
Benjou
(Benjou)
July 24, 2016, 5:41pm
5
Thanks for directing me to the right forum!
It seems that f-droid repo has a problem. I’ll have to figure out how to switch to the google play version without breaking my setup.
Cheers,
You can do an in-app “backup”, uninstall → reinstall from desired store, then in-app “restore”. That should keep the config.
Although i did it back in 0.11/12 (and actually switching from play to f-droid), so it has been a while
Does anybody know when there’ll be a fix for the F-Droid build? How can we help?
canton7
(Antony Male)
August 2, 2016, 7:31am
8
This issue contains the latest info, as far as I know:
Thanks for the information! I guess we’ll have to wait until F-Droid fixes the build.
Apparently they think it should already work, though?
canton7
(Antony Male)
August 2, 2016, 8:12am
10
They thought it should work soon. Apparently “soon” is quite a long time…
Nutomic
(Felix Ableitner)
August 2, 2016, 11:44am
11
I just got the update on F-Droid now (finally).
Noticed that! Many, many thanks!
