syncOwnership doesn't work despite proper capabilities
Hello,
I’ve been scratching my head for some days now. I have an issue related to the syncOwnership option.
I am working with 2 cloud providers (Amazon AWS & Google Cloud Platform). I created an NFS drive on both of them and it is shared by all of my machines within their respective cloud.
Since I have to work with those 2 providers in parallel, I decided to use Syncthing to synchronize some of the folders on the NFS drives, as currently they are being mirrored by me manually which started to be a pain.
On both clouds, I selected a single virtual machine to be the synchronizer (Syncthing runner). On both of them, I created a dedicated user called syncuser. My goal is to have this syncuser work in lingering mode and overwatch selected folders on the NFS.
I set up Syncthing according to the documentation (I used apt-get to install it) and I can confirm that everything works as intended. The only thing that I just can not get to work is the syncOwnership option that I much desire to use.
I keep encountering the following error, whenever a user that is not syncthing-process owner creates a file:
INFO: Puller (folder "/nfs/sync_test" (ogxg4-thtcn), item "example.txt"): syncing: finishing: setting metadata: lchown /nfs/sync_test/.syncthing.example.txt.tmp: operation not permitted
I tried the 2 approaches:
  • user service
  • system service
With the user service, logged in as syncuser, I created an unit file under the following path and filled it in with default values: ~/.config/systemd/user/syncthing.service
I uncommented the AmbientCapabilities=CAP_CHOWN CAP_FOWNER line.
With this setup, I get the aforementioned error. I checked the capabilities:
syncuser@aws:~$ pgrep syncthing
441875
441887
syncuser@aws:~$ cat /proc/441875/status |grep Cap
CapInh:	0000000000000000
CapPrm:	0000000000000000
CapEff:	0000000000000000
CapBnd:	000001ffffffffff
CapAmb:	0000000000000000
syncuser@aws:~$ cat ~/.config/systemd/user/syncthing.service | grep Ambient
It looks that the capabilities were not given. I based my work on this topic. According to it, the CapEff should hold the 0000000000000009 value.
I tried another approach and created an override:
systemctl --user edit syncthing.service
And added the following lines there:
[Service]
And that revealed an underlying issue - the capabilities can not be set:
May 14 09:38:53 aws systemd[961]: syncthing.service: Failed with result 'exit-code'.
May 14 09:38:54 aws systemd[961]: syncthing.service: Scheduled restart job, restart counter is at 1.
May 14 09:38:54 aws systemd[961]: Started syncthing.service - Syncthing - Open Source Continuous File Synchronization.
May 14 09:38:54 aws (yncthing)[441999]: syncthing.service: Failed to apply ambient capabilities (before UID change): Operation not permitted
May 14 09:38:54 aws systemd[961]: syncthing.service: Main process exited, code=exited, status=218/CAPABILITIES
So I decided to go for the system service instead. I created a unit file under /etc/systemd/system/syncthing@.service and pasted the default values and again, I uncommented the AmbientCapabilities= line. I launched the service with:
sudo systemctl start syncthing@syncuser.service
And verified the capabilities again (on both machines):
syncuser@gcp:/etc/systemd/system$ ps aux | grep syncthing
syncuser  442342  0.0  0.0 1249268 18048 ?       Ssl  09:47   0:00 /usr/bin/syncthing serve --no-browser --no-restart --logflags=0
syncuser  442351  0.7  0.0 1251700 29596 ?       SNl  09:47   0:01 /usr/bin/syncthing serve --no-browser --no-restart --logflags=0
syncuser@gcp:/etc/systemd/system$ cat /proc/442342/status |grep Cap
CapInh:	0000000000200109
CapPrm:	0000000000000009
CapEff:	0000000000000009
CapAmb:	0000000000000009
and noticed that the capabilities are there - Syncthing running from syncuser, with the chown capabilities.
What happens on the other machine then? This:
Puller (folder "/nfs/sync_test" (ogxg4-thtcn), item "file.txt"): syncing: finishing: setting metadata: lchown /nfs/sync_test/.syncthing.file.txt.tmp: operation not permitted
So even though the capabilities have been granted, I still get the chown command denied.
Is there anything that I am clearly missing? I was wondering whether this could be an NFS-related issue? Some kind of under-the-hood block for non-root users? I use no_root_squash on my NFS servers and the entire ownerhship synchronization process works when I launch syncthing as root - but I’d like to avoid that.
Capabilities are not communicated to an NFS server and doesn’t give you any rights there. You need to run as uid 0. This is not a Syncthing thing, it’s how NFS works. :person_shrugging:
That confirms my concerns.
Thank you for the response.
