Syncing stuck
Two Windows PCs in LAN syncing between each other. One of them is untrusted. Stuck at 95% forever. Syncthing version is v1.29.7.
I see this: Out of Sync Items [1 items, ~0 B]
When I click it: cache\Android\Storage analyzer.apk 0 B 2025-06-27 12:52:07 i5
I tried creating a file at that path. Nothing changes. I deleted the file. Still nothing.
Screenshots from untrusted PC:
Wow, I did a database reset and now 1326 items are out of sync. I see that it is an old problem with Syncthing, that is never fixed. I guess I will ignore it if it just works.
I think you may want to try upgrading to Syncthing v2, which uses a completely different database format, and see if the problem goes away “naturally”.
Isn’t it beta? Is the beta stable enough?
It’s release candidate already, so I would expect a stable release soon.
