Getting the following error. Syncthing running with root privileges:
[IXUFV] INFO: Puller (folder "termux" (dmsn4-oa6nw), item "home/test4"): syncing: finishing: setting metadata: set xattrs /data_mirror/data_ce/null/0/com.termux/files/home/.syncthing.test4.tmp: Removexattr "security.selinux": permission denied
File is:
u0_a380@jelly2 ~ $ sudo /system/bin/ls -Z test4
u:object_r:app_data_file:s0:c124,c257,c512,c768 test4
Any way to fix it?
