Hello
Apologies if this has been answered before, but I couldn’t find a solution.
My work PC uses webdav folder to store files (not locally on the PC hard-drive).
I’m trying to sync files from my laptop and home PC to my work PC webdav folder.
However, when I try to add the webdav folder, there’s an error: “Failed to create folder marker: file does not exist.”
Any advice will be appreciated
Thanks
Is the drive mounted as a drive letter?
Yes, mapped as Z (in Win 10). The work Webdav at root has two main folders: H-Drive and M-Drive (folder names).
I want to sync with the the H-Drive. So in syncthing, I added Folder Path: Z:\H-Drive
Edit: in synctrazor clicking on the ‘Open Folder’ button does take me to Z:\H-Drive.
I’ve also clicked ignore permissions in advanced settings.
Yeah, sorry, but I think you are on your own.
Webdav is not even a filesystem, it’s a web protocol.
I think most of the guarantees we need are not there for us be able to run.
You should run syncthing on the machine that exposes the storage instead.
