Hi thanks for the tool! However, it seems that syncing latency is very large and sometimes even does not sync. For example, suppose I changed a line of a small local file. Then it takes ~10s for it to be updated in the remote side. Once in a while, syncthing even does not sync it, no matter how I do some extra manually clicks on the buttons on the web ui.
The local and remote computer are both in a local network, and normal ssh to remote computer is super fast, so it does not look like a network issue.
As for why sometimes changes aren’t detected, that would require proper debugging with logs, etc. Forcing a rescan through the Web GUI should still always detect all such changes though.
