have just found that the .stfolder is actually present in the /users/aph/Y-test folder. It is just that finder is set up to hide .* folders.
So the issue must be something else
The failures to write to config.xml need to be resolved for sure!
I changed the permissions in \Applications\Sync so “everyone” has read/write access This may have got rid of the error with not being able to change config.xml but now I have these errors
I then changed the permissions for both config.xml and config.xml.v0 in /Users/aph/Library/Application Support/Syncthing/ to everyone
The cannot write permissions error continues.
What user owns the Syncthing process? Does that user have write permissions in the Folder locations?
Yes. My user name is aph, and I am administrator
It looks like the OS is not allowing the Syncthing process to write files in the Application Support directory. But I don’t know why.
I’m not super smart on Mac file permissions —- can you start Syncthing in a different directory and see if it resolves the issue? There are two ways to do it (from Syncthing — Syncthing documentation):
syncthing —-home=<dir>
Or:
syncthing —-config=<dir> —-data=<dir>
The latter is used when you want the configuration and the database directories to be separate. In that case, you must use both command line switches.
Hi My Mac was in the shop to replace the battery so I have not worked on this until today. I tried the suggestion to define a different home directory, by opening a terminal and typing " ``` syncthing —-home=sync_jab9 where sync_jab9 is a folder I made at the top level.
I then tried to use syncthing but the location I had been using so far to access the web console http://127.0.0.1.8384 but Safari would not connect to that page
=== I have watched a you Tube video on syncthing https://www.google.com/search?client=firefox-b-d&q=syncthing+on+MacOS#fpstate=ive&vld=cid:4417292f,vid:PSx-BkMOPF4,st:0 and decided to delete the version of sycnthing, and follow this guide.
I was ableo to download Syncthing-1.28.0-1.dmg and installed it in Applications
Again, when I tried to access the web console as per the instructions in the video localhost:8384 Safari said it cannot access that page (my wifi is working) Similarly when I tried using http://127.0.0.1.8384 Safari said it cannot access the page.
Any suggestions ?
I deleted syncthing
Ideas:
When running Syncthing — or anything else! —- with command line arguments that contain directories, I strongly suggest the full directory path rather than a relative path.
If you cannot see the Syncthing UI, the first thing to check is that it isn’t a certificate error. The second thing to check is that the Syncthing process is running.
