Forgive the very basic question but I’ve never used a synchronization tool before.
In which direction does the synchronizing occur? Can you force it to go in only one direction?
For instance, can I make file changes on my android phone overwrite the file on the pc, but never the reverse?
If yes, can this be setup in one direction for certain folders and the reverse for other folders?
Thank you.
