I have two large desktop machines w/ terabyte+ drives, one at home and one at my makerspace studio, which I keep pretty much everything in my /home synced between them. Barring power failures and the occasional reboot, they are always on.
I also have a laptop, which is off most of the time, that I use as a travel machine when I need to do stuff away from my main machines. This machine has a much smaller drive, so not possible to sync everything with it.
Like I’d imagine most of us, I have a lot of older stuff in my directories that I probably would never use on the travel machine, and other stuff in the same directories that I’d like to have synced on the travel machine…
Is there a way to set up ST on the travel machine so that it only tries to sync a subset of a directory - i.e. only say ~/documents/projects, but not ~/documents/taxes, if the entire ~/documents is synced between the main machines?
I’d much prefer not to have to increase the already annoyingly large set of directories to sync that I have on the main machines…
Thanks, ex-Gooserider
