Dear all,
Thanks for this great software!
I am interested in knowing more about which file synchronization algorithm is built in Syncthing. I am aware of the Block Exchange Protocol, but the latter only gives low-level information about how peers exchange information, and does not provide a high-level description of how the synchronization state of each file is maintained across all nodes.
Does Syncthing use its tracker to manage a central index of all the available files in a given repository (as in Napster)? Does it automatically create a star-shaped topology for each repository by electing one master node that is responsible for the indexing of this repository (as recommended by Unison)? Does it build a Distributed Hash Table (DHT), as in BitTorrent? Does it use some Version Vectors flavor to track the various versions of each file, together with their adding/removal?
As a side question, what is the Syncthing tracker responsible for, besides maintaining an index of all the (IP address, port) pairs for each peer that is active in this repository?
Thanks for your answer!
Regards, Sébastien-
In theory, this causes unbound growth of the index. In reality, I don’t think this is a problem. If you continually create and delete files with completely random names, you’ll grow the index size by a few tens of bytes per name.
