My configuration:
- 1 Android phone (v1.18.3) an* d 1 Linux Mint computer (1.18.3).
- No nested synced folder, no exclusions.
- 1 folder in Send & receive mode
- 1 folder unidirectional Linux => Android
What happened: Started syncthing for the first time in a few months.
- Sync stuck at 73% on both devices
- Rebooted both devices
- Sync stuck at 73% on the phone and 43% on the Linux
- Upgraded Linux client to 1.18.3 by adding the PPA.
- Same thing
Current situation:
- stuck with above percentages
- list of non-synchronized files contains only content from the unidirectional folder, most of them already exist on the Android device
Log file on Android is empty. Logs on the computer (after reboot and update):
2021-12-23 13:27:31 My ID: 2TDOG27-NXGDVB2-CX2YBIV-GIENCMF-IQLKL4V-QPBF2CR-FKZP64Y-C36G5QU
2021-12-23 13:27:32 Single thread SHA256 performance is 220 MB/s using crypto/sha256 (219 MB/s using minio/sha256-simd).
2021-12-23 13:27:32 Hashing performance is 191.77 MB/s
2021-12-23 13:27:32 Overall send rate is unlimited, receive rate is unlimited
2021-12-23 13:27:32 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2021-12-23 13:27:32 Using discovery mechanism: global discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2021-12-23 13:27:32 Ready to synchronize "Default Folder" (default) (sendreceive)
2021-12-23 13:27:32 Using discovery mechanism: global discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2021-12-23 13:27:32 Using discovery mechanism: global discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2021-12-23 13:27:32 Using discovery mechanism: IPv4 local broadcast discovery on port 21027
2021-12-23 13:27:32 ...
2021-12-23 13:27:32 Using discovery mechanism: IPv6 local multicast discovery on address [ff12::8384]:21027
2021-12-23 13:27:32 TCP listener ([::]:22000) starting
2021-12-23 13:27:32 Ready to synchronize "Photos 2021" (qprzw-mvsp6) (sendreceive)
2021-12-23 13:27:32 QUIC listener ([::]:22000) starting
2021-12-23 13:27:32 Detected 0 NAT services
2021-12-23 13:27:32 Ready to synchronize "Vidéos Édouard" (x7wms-ot4wf) (sendreceive)
2021-12-23 13:27:32 Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
2021-12-23 13:27:32 listenerSupervisor@dynamic+https://relays.syncthing.net/endpoint: service dynamic+https://relays.syncthing.net/endpoint failed: Get "https://relays.syncthing.net/endpoint": dial tcp: lookup relays.syncthing.net on 127.0.0.53:53: server misbehaving
2021-12-23 13:27:32 GUI and API listening on 127.0.0.1:8384
2021-12-23 13:27:32 Access the GUI via the following URL: http://127.0.0.1:8384/
2021-12-23 13:27:32 My name is "a-tact-mint"
2021-12-23 13:27:32 Device MG3EQQU-JOIEPMC-EOAZM3Y-UWF7YFU-MQMRDVC-OXNZCL7-5SZUCQU-OB7VQAT is "Samsung A5 JML" at [dynamic]
2021-12-23 13:27:32 Completed initial scan of sendreceive folder "Default Folder" (default)
2021-12-23 13:27:32 Completed initial scan of sendreceive folder "Vidéos Édouard" (x7wms-ot4wf)
2021-12-23 13:27:33 Completed initial scan of sendreceive folder "Photos 2021" (qprzw-mvsp6)
2021-12-23 13:28:17 Established secure connection to MG3EQQU-JOIEPMC-EOAZM3Y-UWF7YFU-MQMRDVC-OXNZCL7-5SZUCQU-OB7VQAT at 192.168.1.124:22000-192.168.1.178:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2021-12-23 13:28:17 Device MG3EQQU-JOIEPMC-EOAZM3Y-UWF7YFU-MQMRDVC-OXNZCL7-5SZUCQU-OB7VQAT client is "syncthing v1.18.3" named "SM-A520W" at 192.168.1.124:22000-192.168.1.178:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2021-12-23 13:28:45 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2021-12-23 13:29:32 Joined relay relay://74.15.231.225:22067
2021-12-23 13:29:44 Established secure connection to MG3EQQU-JOIEPMC-EOAZM3Y-UWF7YFU-MQMRDVC-OXNZCL7-5SZUCQU-OB7VQAT at 192.168.1.124:22000-192.168.1.178:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2021-12-23 13:29:44 Replacing old connection 192.168.1.124:22000-192.168.1.178:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256 with 192.168.1.124:22000-192.168.1.178:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 for MG3EQQU-JOIEPMC-EOAZM3Y-UWF7YFU-MQMRDVC-OXNZCL7-5SZUCQU-OB7VQAT
2021-12-23 13:29:44 Connection to MG3EQQU-JOIEPMC-EOAZM3Y-UWF7YFU-MQMRDVC-OXNZCL7-5SZUCQU-OB7VQAT at 192.168.1.124:22000-192.168.1.178:22000/quic-server/TLS1.3-TLS_CHACHA20_POLY1305_SHA256 closed: replacing connection
2021-12-23 13:29:44 Device MG3EQQU-JOIEPMC-EOAZM3Y-UWF7YFU-MQMRDVC-OXNZCL7-5SZUCQU-OB7VQAT client is "syncthing v1.18.3" named "SM-A520W" at 192.168.1.124:22000-192.168.1.178:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2021-12-23 13:32:52 quic://0.0.0.0:22000 detected NAT type: Port restricted NAT
2021-12-23 13:32:52 quic://0.0.0.0:22000 resolved external address quic://38.87.9.62:22000 (via stun.syncthing.net:3478)
2021-12-23 13:36:22 Ready to synchronize "Photos 2021" (qprzw-mvsp6) (sendreceive)
2021-12-23 13:36:22 Restarted folder "Photos 2021" (qprzw-mvsp6) (sendreceive)
2021-12-23 13:36:23 Completed initial scan of sendreceive folder "Photos 2021" (qprzw-mvsp6)
2021-12-23 13:57:34 Sent usage report (version 3)
