sync stuck at 99%
I’ve got rpcs3 and aps3e syncing the saves and trophy folders between my cachyos pc and odin 2 portal handheld. the upload from the odin is getting stuck at 99%. I’m syncing other folders including one from /android/data and they work fine.
2026-01-29 11:14:04 INF Synced file (folder.label=aPS3e folder.id=PS3-Saves folder.type=sendreceive file.name=trophy/NPWR00196_00/TROP007.PNG file.modified=“2026-01-29 07:33:17.012242442 -0600 CST” file.permissions=0640 file.size=97560 file.blocksize=131072 blocks.local=0 blocks.download=1 log.pkg=model) 2026-01-29 11:14:04 INF Synced file (folder.label=aPS3e folder.id=PS3-Saves folder.type=sendreceive file.name=trophy/NPWR01435_00/TROP023.PNG file.modified=“2026-01-29 11:01:41.19318625 -0600 CST” file.permissions=0640 file.size=47117 file.blocksize=131072 blocks.local=0 blocks.download=1 log.pkg=model) 2026-01-29 11:14:04 INF Synced file (folder.label=aPS3e folder.id=PS3-Saves folder.type=sendreceive file.name=trophy/NPWR00196_00/TROP001.PNG file.modified=“2026-01-29 07:33:17.008242442 -0600 CST” file.permissions=0640 file.size=68488 file.blocksize=131072 blocks.local=0 blocks.download=1 log.pkg=model) 2026-01-29 11:14:04 INF Synced file (folder.label=aPS3e folder.id=PS3-Saves folder.type=sendreceive file.name=trophy/NPWR00196_00/TROP028.PNG file.modified=“2026-01-29 07:33:17.024242442 -0600 CST” file.permissions=0640 file.size=88577 file.blocksize=131072 blocks.local=0 blocks.download=1 log.pkg=model) 2026-01-29 11:21:22 WRN Failed to acquire open port (mapping=0.0.0.0:22000/UDP id=NAT-PMP@ 10.0.0.1 error=“getting new lease on NAT-PMP@ 10.0.0.1 (external port 57748 → internal port 22000): read udp 10.0.0.21:47192->10.0.0.1:5351: recvfrom: connection refused” log.pkg=nat) 2026-01-29 11:21:32 WRN Failed to acquire open port (mapping=“[::]:22000/TCP” id=NAT-PMP@1 0.0.0.1 error=“getting new lease on NAT-PMP@ 10.0.0.1 (external port 57748 → internal port 22000): read udp 10.0.0.21:45351->10.0.0.1:5351: recvfrom: connection refused” log.pkg=nat) 2026-01-29 11:28:57 INF Lost device connection (kind=secondary device=ZPFW3SQ connection=10.0.0.21:53276-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F7S4JG49922KU1HB02DI1MK2 error=“read timeout” remaining=1 log.pkg=model) 2026-01-29 11:28:57 INF Lost device connection (kind=secondary device=ZPFW3SQ connection=10.0.0.21:53284-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F7S4JI2DFFEELJOUFB94JQRA error=“read timeout” remaining=0 log.pkg=model) 2026-01-29 11:28:57 INF Connection closed (device=ZPFW3SQ connection=10.0.0.21:53284-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F7S4JI2DFFEELJOUFB94JQRA error=“read timeout” log.pkg=model) 2026-01-29 11:28:57 INF Lost device connection (kind=primary device=ZPFW3SQ connection=10.0.0.21:22000-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F7S4JD6GFHI6SLLB2QPU5IMU error=“read timeout” remaining=2 log.pkg=model) 2026-01-29 11:28:58 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:22000 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64F8F7V3CGNHGK62SOJBHJRS6O log.pkg=connections) 2026-01-29 11:28:58 INF New device connection (device=ZPFW3SQ address=10.0.0.29:22000 remote.name=“Odin2 Portal” remote.client=syncthing remote.version=v2.0.13-1-gb7b494b7c log.pkg=model) 2026-01-29 11:28:58 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:42656 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64F8F7V507OCIOPHALVSCH4BK0 log.pkg=connections) 2026-01-29 11:28:58 INF Additional device connection (device=ZPFW3SQ address=10.0.0.29:22000 count=1 log.pkg=model) 2026-01-29 11:29:58 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:55284 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64F8FEVBTOCM8C689UK48JGGLQ log.pkg=connections) 2026-01-29 11:29:58 INF Additional device connection (device=ZPFW3SQ address=10.0.0.29:22000 count=2 log.pkg=model) 2026-01-29 11:43:59 INF Lost device connection (kind=secondary device=ZPFW3SQ connection=10.0.0.21:42656-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F8F7V507OCIOPHALVSCH4BK0 error=“read timeout” remaining=2 log.pkg=model) 2026-01-29 11:43:59 INF Lost device connection (kind=primary device=ZPFW3SQ connection=10.0.0.21:22000-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F8F7V3CGNHGK62SOJBHJRS6O error=“read timeout” remaining=1 log.pkg=model) 2026-01-29 11:44:00 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:22000 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64F8IH1UFPC4MIE0BHQ2B7K776 log.pkg=connections) 2026-01-29 11:44:00 INF Additional device connection (device=ZPFW3SQ address=10.0.0.29:22000 count=1 log.pkg=model) 2026-01-29 11:45:01 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:41642 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64F8IO23DIDPSC21HVKM3DKVV8 log.pkg=connections) 2026-01-29 11:45:01 INF Additional device connection (device=ZPFW3SQ address=10.0.0.29:22000 count=2 log.pkg=model) 2026-01-29 21:24:31 INF Lost device connection (kind=secondary device=ZPFW3SQ connection=10.0.0.21:41642-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F8IO23DIDPSC21HVKM3DKVV8 error=“reading length: read tcp 10.0.0.21:41642->10.0.0.29:22000: read: connection reset by peer” remaining=2 log.pkg=model) 2026-01-29 21:24:31 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:41206 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64FCH802GL69UDBEAKT09CI2BK log.pkg=connections) 2026-01-29 21:24:31 INF Additional device connection (device=ZPFW3SQ address=10.0.0.29:22000 count=2 log.pkg=model) 2026-01-29 21:24:33 WRN Abandoning old index handler in favour of new connection (device=ZPFW3SQ old=64F8FEVBTOCM8C689UK48JGGLQ new=64FCH802GL69UDBEAKT09CI2BK log.pkg=model) 2026-01-29 21:24:34 INF Lost device connection (kind=primary device=ZPFW3SQ connection=10.0.0.21:55284-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F8FEVBTOCM8C689UK48JGGLQ error=“reading length: read tcp 10.0.0.21:55284->10.0.0.29:22000: read: connection reset by peer” remaining=2 log.pkg=model) 2026-01-29 21:24:34 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:41214 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64FCH8AL5SKJIB9K5A296QU890 log.pkg=connections) 2026-01-29 21:24:34 INF Additional device connection (device=ZPFW3SQ address=10.0.0.29:22000 count=2 log.pkg=model) 2026-01-29 21:24:35 INF Lost device connection (kind=primary device=ZPFW3SQ connection=10.0.0.21:22000-10.0.0.29:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-64F8IH1UFPC4MIE0BHQ2B7K776 error=“reading length: read tcp 10.0.0.21:22000->10.0.0.29:22000: read: connection reset by peer” remaining=2 log.pkg=model) 2026-01-29 21:24:35 INF Established secure connection (device=ZPFW3SQ connection.local=10.0.0.21:22000 connection.remote=10.0.0.29:22000 connection.type=tcp-client connection.lan=true connection.crypto=TLS1.3-TLS_AES_128_GCM_SHA256 connection.prio=10 connection.id=64FCH8EG76U06QR52SDO7ID11S log.pkg=connections) 2026-01-29 21:24:35 INF Additional device connection (device=ZPFW3SQ address=10.0.0.29:22000 count=2 log.pkg=model) 2026-01-29 21:25:40 INF Joined relay (uri=relay://165.140.202.197:22067 log.pkg=relay/client) 2026-01-29 21:27:40 WRN Failed to acquire open port (mapping=0.0.0.0:22000/UDP id =NAT-PMP@ 10.0.0.1 error=“getting new lease on NAT-PMP @10.0.0.1 (external port 57748 → internal port 22000): read udp 10.0.0.21:47322->10.0.0.1:5351: recvfrom: connection refused” log.pkg=nat) 2026-01-29 21:27:50 WRN Failed to acquire open port (mapping=“[::]:22000/TCP” id=NAT-PMP@ 10.0.0.1 error=“getting new lease on NAT-PMP @10.0.0.1 (external port 57748 → internal port 22000): read udp 10.0.0.21:54264->10.0.0.1:5351: recvfrom: connection refused” log.pkg=nat) 2026-01-29 21:29:13 INF Ready to synchronize (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:29:13 INF Restarted folder (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:29:13 INF Completed initial scan (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:31:58 INF Paused folder (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:32:00 INF Ready to synchronize (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:32:00 INF Unpaused folder (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:32:00 INF Completed initial scan (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:42:56 INF Removing folder (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:42:56 INF Removed folder (folder.label=Rpcs3 folder.id=PS3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:44:05 WRN Unexpected folder ID in ClusterConfig; ensure that the folder exists and that this device is selected under “Share With” in the folder configuration. (folder.label=aps3e folder.id=Ps3-Saves device=ZPFW3SQ log.pkg=model) 2026-01-29 21:44:24 INF Adding folder (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:44:24 INF Ready to synchronize (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:44:24 INF Peer has a new index ID (device=ZPFW3SQ folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive indexid=0xCCDF3E743465890F log.pkg=model) 2026-01-29 21:44:24 INF Completed initial scan (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive log.pkg=model) 2026-01-29 21:44:26 INF Created or updated directory (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive dir.name=exdata dir.permissions=0770 log.pkg=model) 2026-01-29 21:50:44 INF Deleted file (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive file.name=exdata/UP9000-NPUA80663_00-SLY1US030100SHIP.rap log.pkg=model) 2026-01-29 21:50:44 INF Deleted file (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive file.name=exdata/UP9000-NPUA80073_00-PAIN000100000000.rap log.pkg=model) 2026-01-29 21:50:44 INF Deleted file (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive file.name=exdata/UP9000-NPUA80664_00-SLY2US030100SHIP.rap log.pkg=model) 2026-01-29 21:50:44 INF Deleted file (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive file.name=exdata/UP0102-NPUB30021_00-COMMANDO90123456.rap log.pkg=model) 2026-01-29 21:50:44 INF Deleted file (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive file.name=exdata/UP9000-NPUA80665_00-SLY3US030100SHIP.rap log.pkg=model) 2026-01-29 21:50:44 INF Deleted directory (folder.label=rpcs3 folder.id=Ps3-Saves folder.type=sendreceive dir.name=exdata dir.permissions=0770 log.pkg=model) 2026-01-29 21:58:15 WRN Failed to acquire open port (mapping=0.0.0.0:22000/UDP id=NAT-PMP @10.0.0.1 error=“getting new lease on NAT-PMP @10.0.0.1 (external port 57748 → internal port 22000): read udp 10.0.0.21:33031->10.0.0.1:5351: recvfrom: connection refused” log.pkg=nat) 2026-01-29 21:58:25 WRN Failed to acquire open port (mapping=“[::]:22000/TCP” id=NAT-PMP @10.0.0.1 error=“getting new lease on NAT-PMP @10.0.0.1 (external port 57748 → internal port 22000): read udp 10.0.0.21:57373->10.0.0.1:5351: recvfrom: connection refused” log.pkg=nat)
Vould you check the out of sync items in the GUI?
just files from the folder that’s supposed to sync.
I’m sorry I cannot check the details you’ve shared, but when I face a similar issue, it’s usually because of:
  • File permissions on one device are preventing the modification of files, or
  • There are save conflicts, where the files have been changed on both devices while disconnected, and then sync is attempted, or
  • you have sync exclusion rules, and one folder is deleted on one device, but it’s not empty on the other device, but exclusion rules do not allow syncing its contents.
