i’ve got two client with a shared folder that are stuck on 95% with 0B to sync.
I use a .stignore
I have clean synced the folder in the past, and did not change anything in .stignore
It’s a send and receive folder
Local and global states show show the same file count on both sides
Sending side shows 0 out of sync items
Receiving side looks like it’s cleanly synced
File systems are the same on botch sides (ntfs)
Im quite at a loss what could be the issue here, if there is an issue at all. Is there any way (log) to check if there is out-of sync files or could this be an ui bug of some sort ?
Hmm, no idea what the problem is then. Can you run curl -X GET -H "X-API-Key: yourapikey" 'http://localhost:8384/rest/db/completion?device=deviceid&folder=folderid' | json_pp on the sending side with the device id of the receiving side? That should list the file that it thinks is missing.
There is at least one bug, that I reported and hopefully fixed (as in the linked issues and PR). That a file that was ignored was reported as out of sync might be one more bug, but given the information available I can’t be sure. And given that mt7479 already resolved its issue, it is not likely that there is going to be more evidence to dig for another bug.
