sync stuck at 0%, devices connected
I’m running Syncthing on a M2 MacBook Air, and Android 11 on an e-ink tablet. I have Syncthing up and running on both. They seem to recognize one another, and dno’t show ‘disconnected’ or any errors. But they don’t sync. They just sit at 0%, with the up and down speeds sometimes flickering around 40-74 B/s. What am I doing wrong here? (ETA I’ve restarted both devices.)
Please post screenshots of the Web GUI from both sides. On Android, you can access the Web GUI using the left slide-out menu.
that did it! I didn’t know I had to add individual folders via GUI as well as the connection and destinations set up in the initial link.
Glad the quick tip helped! Please check https://docs.syncthing.net/intro/index.html if you haven’t already for a quick introduction to the GUI and how the basics of Syncthing work.
