sync samsung j6+ android ver: 8,1,0 ext sd card is not sync able..
i can sync the internal folder, but can’t access sync to external sdcard folder.
i think android 8 and above uses emulated ext sdcard condition for privacy reason. hence no longer direct accessible. i tried to use droidvim to access and store external sdcard… but the address shown on droidvim address is very weird and long… in "emulated/0/… long long address…/ "
anyway to overcome ? thanks
how do you know android 11 will have overcome of this issue ?
any idea what syncthing has todo with kde connect ?
why kde connect able to send files from my external sd card, yet syncthing can’t ? should be achievable.
