I am a new user and I am getting sync-conflict files when they dont seem appropriate. I just edit the file on the local machine that has the shared folder and then sync-conflict files appear for it there and in the same folder on the server machine. Seems like they should only appear if I changed it on both machines, which would actually be a conflict.
I am using PDF Reader Pro Lite to edit the file. I thought maybe it had something to do with how PRPL was using temp files. So I Moved the file out of the shared folder on the local machine to an unshared folder before editing it, then moved it back to the shared folder. Same problem; sync-conflict file appears.
So then I tried Copying the file out of the shared folder to an unshared folder, making the edits and then copying it back, replacing the original. Same problem.
Later… I just see now that the Mac-OS 64-bit Universal V 1.23 is on Syncthing | Downloads I dont know if this is the version I downloaded. The server version is Embassy One V 1.22.1-1 So I guess I have to resolve that. But is this a problem that others are having?
