Hi, Can I know if its possible to automatically sync all content from seedbox to windows laptop? Appreciate some guidance on the setup. Thanks
Basic setup: https://github.com/syncthing/syncthing/releases/tag/v0.14.40 | docs.syncthing.net
Seedboxes: https://forum.syncthing.net/search?q=seedbox
Or in other words: Please do a minimal amount of research and then try it out and ask questions about actual problems if any come up (and yes of course it is possible).
Hi, Im unable to locate the device id for the seedbox. Kindly advice. Thanks
I assume you didn’t get access to the web UI (you can do that with ssh port forwarding): https://docs.syncthing.net/users/syncthing.html#cmdoption-device-id
