Hello,
I’m using Syncthing between my Ubuntu notebook (Syncthing version 1.4.2) and my ARM-based router with entware (Syncthing version 1.1.4).
Generally it’s syncing quite good, I’m syncing about 100GB of data. What I can’t figure out is why my symlinks get ignored by Syncthing: everything results “in sync”, despite symlinks not being synced at all. They are simply ignored.
Both the router and the notebook use an EXT3 file system.
The setup is:
notebook = send only
router = receive only
As far as I understand the FAQ says:
Symbolic Links (synced, except on Windows, but never followed.)
Symlinks are not reflected in the item count, neither by the “sender” nor by the “receiver”. Both the sender and the receiver count the same number of files, which is the correct one if you exclude the symlinks.
The “sender” is permitted to read the symlinks, since they are on the Desktop.
The symlinks targets are located in other folders (some of which are synced, some are not synced, and some belong to the root user), but as far as I’m aware this is not relevant.
One minor request though: since I upgraded my router from v_1.1.4 to v_1.4.2 the GUI doesn’t show cpu and ram utilization. The same happens on my notebook, which has the same v_1.4.2.
How to get cpu and ram utilization back?
