"In normal configuration, Syncthing will always connect to relays, as it cannot know, if other devices need them and will connect through them to it.
To be totally private (to the extreme), disable relay and global/local discovery, set the listening address to something explicit, like tcp://:22000 instead of default and set the addresses of the remote devices to their hostname/ip address and port (like tcp://192.168.01.45:22001) instead of dynamic. And disable usage reporting and auto upgrade (if you really want).
Then the only connections Syncthing will ever make are direct connections to the other syncthing devices."
regarding the comment above,
can i add listening address to tcp://:12345 or tcp://:56789 instead of tcp://:22000.
and if i dont add remote devices address like tcp://192.168.01.45:22000 and i add like 22001 or 22002 it doesn’t connects to it.
i added password and username to gui but it adds serveral other characters to it(password). i think its not working.
when i go to 127.0.0.1:8384 address the android gui and windows’ gui have different GUI Authentication User name. so if i add the password on gui windows, is it added to android gui too. im asking this cuz both have this 127.0.0.1:8384 web-address.
do i need to setup both android phone and pc windows’ syncthing listen address to connect both pc and phone. and does the listen address of pc and phone needs to be same like tcp://:22000.
