I am running SyncThing on 2 computers A and B. My “root” folder is my user home folder on both, as per-default.
From A, I share ~/work/example
using id example
On B this folder is synched as ~/example
I would like to be able to retain the same directory structure on both A and B (~/work/example
), and to do the same for other sub directories as well.
Is it possible ?
I sense I can do something similar by sharing the a parent folder folder and using ‘include’ (negative !
) entries in .stignore
, but I also understand that would cause watching the entire home ~
which is undesirable.
