I don’t want device:“target” to synchronize the delete file operation of device:“source”
After I delete a file on device:“source”, although the device:“target” did not delete, the synchronization has not been completed,stuck at “syncing (95% 0B)”:
This is normal when using that option. Nothing can be done about the out of sync items, and the two devices will remain permanently out sync (which they actually are) unless you decide to disable that option, which will then cause the previously ignored deletions to sync.
If you want to still continue to use it, you need to learn to live with the “incomplete” sync status.
