I suspect we only support running a single instance at a time and the failure is caused by the fact the certificate it gets does not match what we expect (because it connects to the instance in the previous profile).
I guess you can test this by checking that it’s always the second instance you try and launch is failing.
This doesn’t happen all the time, only on occasion, and gets fixed with a reboot.
Meaning most of the time both profiles are running Syncthing successfully.
But having to reboot every day is obviously not right.
Profile support is native Android functionality and has been since Android 6.
I think every app should support it.
The android app is maintenance mode, and nobody is working on it, so its unlikely to happen.
From the error you posted I am fairly certain the error is due to the app trying to connect to the syncthing instance of the other profile, not sure why that happens only sometimes however.
Actually I retract my previous statement about it happening on occasion.
You’re right, whichever profile I ran it first on, it will fail on the other profile.
No no, it happens all the time.
I’ve just retested.
I had no idea.
Kinda weird considering most people have probably heard about Syncthing because they wanted to sync their phone with their computer haha
