Not sure why I am having so many build isues, but since I updated to the latest commit, I can not build the project. I get the following error:
cmd/syncthing/main.go:620: cfg.Options.LocalAnnPort undefined (type config.OptionsConfiguration has no field or method LocalAnnPort)
This makes no sense to me since I see that the field was added to the OptionsConfiguration type in config.go. Has anyone run into strange compile issues like this before?
Well I figured out what it is, and what has been giving me all of my build issues. Since a lot of things are imported using the path github.com/calmh/syncthing the source file gets loaded from $GOPATH/src/github.com/calmh/syncthing/ and not $GOPATH/src/github.com/KayoticSully/syncthing/ which is where my forked repo that I am working on is.
The work-around I am using now is to replace the folder at $GOPATH/src/github.com/calmh/syncthing/ with a symbolic link to $GOPATH/src/github.com/KayoticSully/syncthing/. Is there a more developer friendly way we can manage the imports? Or is this just a step that needs to be added to the build setup page?
This is a commonly discussed issue in the Go community; I “hint” at it in the building page, with something like “you may think you want the code somewhere other than ~src/github.com/calmh/syncthing but you don’t”. What you probably want to do is either the symlink you already have, or simply
cd ~/src/github.com
rm -rf calmh
mkdir calmh
cd calmh
git clone git@github.com/KayoticSully/syncthing
so you get your repo, checked out with the correct import path.
