Wait, so I edit/update the ignore patterns in/through the Syncting Android app which creates the .stignore file inside the folder on my Android. Am I doing it wrong? My Syncting works btw my phone and my NAS.
Yeah, I’ve got a feeling something isn’t right there. Can you open the Web GUI on Android using the left slide-out menu, then go to “Edit Folder” there and see what the ignore patterns look like?
The above should work (except the last ? which shoudn’t be there).
Could you write below all the steps you’ve been trying to do in details? Including some example PDF filenames will also help. More screenshots of the GUI showing the folder in question, including its local and global state will be useful too.
Sometimes I use this kind of list to exclude all stuff but pattern. Although my list is like this (notice the difference on the last line) :
!<stuff to sync pattern>
Isn’t it dangerous to have (?d)* instead, which IIUC means “Allow any deletion requested by peers”, even beyond the ones “OS generated files” according to the ignore doc which ST has no way to know without relaying on files attributes (but an attribute as S for System does not exist in e.g. linux ext FS AFAIK).
