Stignore - not working?
I’ve read the .stignore docs, and can’t figure out the simplest possible pattern.
I’ve tried node_modules and node_modules/, and in both cases the directory is still synced.
What am I missing?
Where is your .stignore file located? For example, if the Syncthing folder’s root directory is syncthing and it contains a subdirectory node_modules, the bare minimum directory listing should look like the following:
syncthing/
├── node_modules
├── .stfolder
└── .stignore
The first pattern matches anything named node_modules, including files and directories, while the second pattern node_modules/ applies only to the contents of any directory with a matching name.
Are you trying to ignore any directory named node_modules or just the one at the root of the Syncthing folder?
Ah, I missed:
The .stignore file must be placed in the root of the synced folder.
Thanks!
