GUI shows Android device as stuck at “Syncing 50%” even though everything seems to be up to date
Device 2: Android
v0.13.2
Devices tab shows everything as “up to date”
Cause of the problem
One shared folder on Android device contains a .stignore because I only want one specific file in the folder to be synced, so the .stignore is like:
!file-i-want-synced
If I tell Ubuntu device not to sync the folder that contains the .stignore on Android device, then sync reports 100% on Ubuntu. Hence, that’s what indicates it’s an issue relating to .stignore.
The side that shows 50% doesn’t know the other side is deliberately ignoring the files - it just knows it hasn’t synced them. But yes this may get improved at some point.
