.stignore blues
Hi
I am trying to ignore some large files and trying to get only one particular directory from a shared repo.
This is my .stfiles (which is included in .stignore)
!.stfiles
!@EMU
*.hdf
Emu folder is synced nicely but I still get those .hdf files inside that folder. Basically I do not want the .hdf files
thanks
It stops processing ignores after hitting the first match, which I suspect is the @EMU inclusion, as its still part of the path of the file you are trying to ignore.
You need to put the ‘*.hdf’ in .stignore in the Emu folder
It does not work.
I got the blues.
I do not care how I have to layout this .stignore stuff but I just want the @EMU folder from the sync and ignore all the .hdf files from @EMU otherwise I run out of space on my device.
thanks
Cam you actually provide the paths of the files (both you are trying to sync and ignore) and actual content of .stignore.
(SYNCROOT)/@EMU (I just want this folder from the whole SYNCROOT) (SYNCROOT)/@EMU/@AMI/Amik.hdf (I do not want this file and other *.hdf)
(SYNCROOT)/.stignore (SYNCROOT)/.stfiles
.stignore #include .stfiles
.stfiles !.stfiles !@EMU *.hdf *
If I understand it correctly, your .stfiles should have this:
!.stfiles
*.hdf
!@EMU
In your current .stfile the *.hdf is unnecessary because the * in the next line already ignores all files.
This could also work:
!.stfiles
!@EMU
@EMU/**.hdf
I already said, move *.hdf above @EMU
Sorry if I missed that part but I did not see your reply as a solution. It sounded like a comment before.
I tested @Chris_Greens solution which did not work.
Thanks I will try it.
