It would be fantastic should the ability to set a static IP on say a notebook, laptop or a mobile device when one is at base LAN - while being capable of switching to a dynamic IP when elsewhere.
By base LAN I am referring to a network you are often connected to such as your home locality.
elsewhere - well - is elsewhere… LTE, public hotspots, friends or family networks etc.
The way this could be implemented would be by using the self-check that the global discovery already seems to do (correct me if I am mistaken) to find the IP of the network you are currently on. If it matches a preset “base” IP it switches to home lan with static IP’s. The standard mode would be the global discovery and only if detected on a home network switched to the preset static IP.
Potentially the ability to add more “base LAN’s” so that one can have a network at work, home and educational institution etc.
I would love to code this feature myself but I am only just learning to program - but it seems to me that this should be fully possible to implement and at that a rather useful feature
It would - again correct my lack of understanding if I am wrong - negate the need for open ports in the router, allow users to use hardcoded local firewalls and increase the speed of discovery along with being less dependent on a 3rd party service to the network.
Possibly this could be a feature one could switch on and off. Or possibly even a plugin if you have plans to make syncthing modular.
Hope this can be used for something or at least inspire!
Cheers,
