kahun
(kahun)
December 30, 2015, 6:09pm
1
Hi
I have been using Arm version on Android (via Termux) for a while. One thing that seems excessive is that it seems like Syncthing is checking for releases every couple minutes even when the wifi is down or when there is connection issues.
Would not it make sense if the release check is done only one or two times a day at most especially on arm builds given that most of these arm devices are low powered or battery operated? Why create network activity if it is not needed that much?
calmh
(Jakob Borg)
December 30, 2015, 6:42pm
2
Releases are looked for every 24 hours, and when the GUI is opened (in order to show the upgrade prompt button).
kahun
(kahun)
December 30, 2015, 6:43pm
3
Well that is not what my log is saying. I will try to paste the log here when Iget a chance.
kahun
(kahun)
December 30, 2015, 6:45pm
4
Ok
Here is the log. I see this line every couple minutes in my log
18:42:10 VERBOSE: External port mapping changed; new port is 61479.
[HD6OA] 18:42:10 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup
+api.github.com on [::1]:53: read udp [::1]:56929->[::1]:53: read: connection refused
[HD6OA] 18:42:10 INFO: Automatic upgrade: no version to select
calmh
(Jakob Borg)
December 30, 2015, 6:48pm
5
Ah. If the connection fails due to something that looks like a temporary network error it is retried in a minute, yes. In this case it looks like it’s failing to talk to the DNS server on localhost.
kahun
(kahun)
December 30, 2015, 6:50pm
6
Yes sure but would not it nice if there is a setting so that user can change that behavior. According to the log above ST gets frantic when there is a connection issue as you mentioned.
calmh
(Jakob Borg)
December 30, 2015, 6:51pm
7
Actually no, I was wrong. It looks like it should wait a full check interval (12 hours) before retrying. Something else is going on here. What is your upgrade interval set to in the config? (autoUpgradeIntervalH)
kahun
(kahun)
December 30, 2015, 6:52pm
8
I think it is the default value. It shows up as 12
calmh
(Jakob Borg)
December 30, 2015, 6:55pm
9
I don’t see how that can result in a check more than once every 12 hours, errors or no… But it certainly looks that way from the logs.
kahun
(kahun)
January 2, 2016, 6:13pm
10
Any more ideas recommendations for this issue?
Provide steps to reproduce it, as it doesn’t happen for me.
kahun
(kahun)
January 2, 2016, 6:46pm
12
Disable network, make it so it can’tt check the releases. This is the only situation I have here.
This is also the arm version running on Android Termux terminal.
kahun
(kahun)
January 2, 2016, 7:08pm
13
HD6OA] 18:33:27 INFO: UPnP parse: unrecognized UPnP device of type urn:schemas-upnp-org:device:InternetGatewayDevice:1
2016/01/02 18:37:44 http: TLS handshake error from 127.0.0.1:39743: remote error: unknown certificate
2016/01/02 18:37:45 http: TLS handshake error from 127.0.0.1:38898: remote error: unknown certificate
2016/01/02 18:37:45 http: TLS handshake error from 127.0.0.1:52128: remote error: unknown certificate
2016/01/02 18:37:45 http: TLS handshake error from 127.0.0.1:47126: remote error: unknown certificate
[HD6OA] 18:37:50 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:39207->[::1]:53: read: connection refused
[HD6OA] 18:39:35 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:45326->[::1]:53: read: connection refused
[HD6OA] 18:41:27 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:46691->[::1]:53: read: connection refused
[HD6OA] 18:43:36 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:42534->[::1]:53: read: connection refused
[HD6OA] 18:45:25 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:51093->[::1]:53: read: connection refused
[HD6OA] 18:46:46 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:45379->[::1]:53: read: connection refused
2016/01/02 18:46:47 http: TLS handshake error from 127.0.0.1:39397: remote error: unknown certificate
2016/01/02 18:46:47 http: TLS handshake error from 127.0.0.1:41337: remote error: unknown certificate
2016/01/02 18:46:47 http: TLS handshake error from 127.0.0.1:51789: remote error: unknown certificate
2016/01/02 18:46:47 http: TLS handshake error from 127.0.0.1:55961: remote error: unknown certificate
[HD6OA] 18:48:53 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:59436->[::1]:53: read: connection refused
[HD6OA] 18:50:46 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:59423->[::1]:53: read: connection refused
2016/01/02 18:59:38 http: TLS handshake error from 127.0.0.1:34650: remote error: unknown certificate
2016/01/02 18:59:38 http: TLS handshake error from 127.0.0.1:37962: remote error: unknown certificate
2016/01/02 18:59:38 http: TLS handshake error from 127.0.0.1:51568: remote error: unknown certificate
2016/01/02 18:59:38 http: TLS handshake error from 127.0.0.1:45121: remote error: unknown certificate
[HD6OA] 18:59:42 INFO: Couldn’t fetch release information: Get https://api.github.com/repos/syncthing/syncthing/releases?per_page=30: dial tcp: lookup api.github.com on [::1]:53: read udp [::1]:40730->[::1]:53: read: connection refused
[HD6OA] 19:03:30 INFO: UPnP parse: unrecognized UPnP device of type urn:schemas-upnp-org:device:InternetGatewayDevice:1
It’s failing to connect to your local DNSMASQ server.
I think it might try to look up the IP in a few different networks, hence why you see multiple errors.
kahun
(kahun)
January 2, 2016, 7:34pm
15
Fine, but would not it make sense if it stops after a while? It keeps trying very frequently as long as ST is running.
The issue is not that it is failing to query dns server, the issue is that it is doing this every couple minutes.
calmh
(Jakob Borg)
January 2, 2016, 7:38pm
16
Those other TLS errors you’re seeing is someone talking to the GUI and failing, due to not liking our certificate. This (the upgrade checks) is for sure an effect of that thing calling /rest/system/upgrade to fetch upgrade information. Our web GUI does it once on first load, but perhaps you’re reloading the page or perhaps the Android app retries upgrade checks on failure. It’s not the automatic upgrade mechanism.
kahun
(kahun)
January 2, 2016, 7:39pm
17
It does it even when Web gui is not running.
calmh
(Jakob Borg)
18
calmh:
Or something else, I have no way of knowing.
kahun
(kahun)
January 2, 2016, 7:40pm
19
I am not using the Addroid app. This is the arm version.
calmh
(Jakob Borg)
20
The fact remains. Those entries http: TLS handshake error is someone talking to the REST service, i.e. the GUI or something else.
