I have 10 Synology’s across the globe. I have all but 1 of them set to receive only as I want the master files updated/ controlled by 1 Synology to limit multiple updates. How should I set it up so that if a file is changed on one of the receive only Synology’s it reverts back to what the send/receive Synology has. Thank you
If the nine receive-only Synology units aren’t supposed to accept any changes other than from the one send-receive Synology, it’d be less complicated and more reliable to make the folder read-only to whatever/whoever is accessing it at the remote sites.
We do exactly this. We found a few cases where people were modifying the remote files but they shouldn’t have been. When we see local changes we investigate why the files were changed, then either copy the modified files to the master or revert local changes.
But what you’re saying is if there are any changes you want to blow them away anyway. So you’re better off preventing the access in the first place so they can’t be changed from the beginning.
